First off, which ones were you thinking of? I think you can use just about any hex adapter that is 12mm. What do you think Rob?
If you are still running the pin style, I can recommend something. I had the same problem with my rims stripping out, until I realized that there is this little washer that goes in between the rim and the bearing race. I found that the previous owner put the washer in between the two rear bearings inside the hub where what spacer goes. So I put it on the outside where it is supposed to be. This allowed me to tighten down my lug nut all the way without the wheel seizing up. Before it would seize up from the rim rubbing on the hub, but the washer spaces things out and doesn't allow that to happen. So basically, just check to see if there is a little washer and make sure you can tighten down your wheel without it seizing up.
Otherwise, you should be able to use the Losi hex adapters, I believe.
