OVERHEATING SPITFIRE PROBLEM SOLVED
In addition to the already discussed cooling system modifications detailed on our Park Flyer forum thread, a decisively important but barely noticeable opening installed on the right side of the tail section in the lower "rudder hinge area" works perfectly to keep the ESC "touchably warm" after a more or less normal flight in 80 degree weather conditions. I used sharpened metal tubing to create the opening in the bottom right side rudder hinge area (can only be seen from the right rear view of the plane) to clear out a channel through to the inside of the rear section of the fuselage. The battery compartment was also made less restrictive for better air flow through the aft sections of the wing radiators and the new vent in the rudder area. Ram air through the hollowed out engine air intake as well as the slightly enlarged three prop blade openings and small spinner/fuselage gap area seems to help provide a nice balanced cooling system for great war combat emergency power demonstrations.
The vertical stabs on both of my Mk IX Spitfires are also modified for purely aesthetic reasons to look more like the one depicted in the above picture that I hope will remain on this post.
It's time to get back in the fight.
Out.
FIGHTERS - AVIATION'S ULTIMATE CALL TO GLORY, HONOR, AND IMMORTALITY (Rom. 2)
__________________________________________________ _______________
Spitfire Brotherhood (All Spitfires Welcome) #64 - Post #408 - Battle of Britain & Winston Churchill relevancy to modeling -
http://www.rcuniverse.com/forum/fb.asp?m=11007416 See why we fight -
www.goodfight.com
__________________________________________________ ________________
The following URL brings up the most concise, non-technical (with technical references) discussion about the revolutionary THORIUM PLASMA BATTERY technology I have found on the web. ENJOY! Oh what fun we are going to have in the future of flight!
http://www.ecocarforum.com/ev-forums...t_a_recha.html
GOOGLE <
https://www.google.com/ > " FIGHTERS - AVIATION'S ULTIMATE CALL TO GLORY, HONOR, AND IMMORTALITY (Rom. 2) " to show the close relationship between ULTIMATE ENERGY TECHNOLOGY and AVIATION'S ULTIMATE CALL TO GLORY.
PS
http://www.rcuniverse.com/community/...g&memid=266748 might help show a motive behind the destruction of my web sites and pictures.
https://www.facebook.com/richard.porter.167 brings up a sample of some of my latest web warfare that's keeping me pinned down a lot.
