RCU Forums - View Single Post - Viability of sharing a turbine between 2 models..
Old 06-12-2014 | 01:07 PM
  #60
Morewatts
I've been moving a B100F between two aircraft. It's only takes minutes but I had to move ECU, pump and turbine. I tried to keep the fuel system intact and just move the ECU and turbine. It did not work as the pump curves were so different that I would have had to change the pump starting voltage to avoid a hot start.
