RCU Forums - View Single Post - Building a Dynaflite Super Decathlon
Old 06-14-2014 | 06:18 PM
  #1919
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Originally Posted by peter.taylor
Thanks very much for taking the time to explain this process to me, covering is way off I just started the build but as I look at some of the post on this form and see the all the planes covered like they came out of a factory I wondered how it was done. Also glad for the tip on making the templets did not know how to get those. Use to live in Houston 15 years ago live in Orlando now. Peter T
Here's a thread on RCU that does a very good job of explaining the Windex method. It has a lot of pictures and is very informative. Just remember that this method only works when you are using Monokote and will not work with any other brand of covering. I have used this method of applying graphics like this many times and it's a great way of applying graphics to a plane and on large surfaces like this it works out a lot better than trying to use heat, as when using heat you'll usually wind up with a lot of bubbles stuck under the graphic.
Applying covering using the WIndex Method
Hope this helps
Ken
