Originally Posted by
RCKen
Here's a thread on RCU that does a very good job of explaining the Windex method. It has a lot of pictures and is very informative. Just remember that this method only works when you are using Monokote and will not work with any other brand of covering. I have used this method of applying graphics like this many times and it's a great way of applying graphics to a plane and on large surfaces like this it works out a lot better than trying to use heat, as when using heat you'll usually wind up with a lot of bubbles stuck under the graphic.
Applying covering using the WIndex Method
Hope this helps
Ken
If you use the self adhesive trim strips, plain soapy water will work.
That is exactly what the automotive industry uses to apply graphics. I've used that method Aw/great success.
