Originally Posted by
WILDCRASHWILLY
I knew early on that this model was building tail heavy. I just never really thought about it being an issue with me as i was using a 40 cc gas engine. Boy was i wrong. I have some pull/pull cable so i'm going to start with that.
If you are using a light weight wood or composite prop switching to a heavier nylon prop will also help more than the equivalent firewall weights.
