Originally Posted by
SrTelemaster150
The rule of thumb is at 1oz in the tail equals 5ozs in the nose.
Actually it all depends on the ratio of length forward & aft of the CG. The shorter the nose moment compared to the tail length, the larger the ratio.
Placing the nose weight as far forward as possible also helps. A large prop nut or spinner adaptor will offset tail weight better than a similar weight on the firewall. Measure the distance from the prop nut to the CG, then, from the CG to the tailwheel. Divide the later by the former & you will give you your ratio. Some small diameter cable from a pull/pull set-up would also save weight.
I wouldn't eliminate the flying wires, but if you know an angler that has some of the new high tech braided fishing line. That might work just as well & weigh a lot less.
Build light in the tail & don't be too concerned W/the weight ahead of the CG.
To add to this some Decathlon specifics. the nose is approximately 12 inches ahead of the CG and the tail is about 36 inches behind the CG so for the decathlon, that ratio is about 3:1, or 1 ounce in the tail will require an equivalent 3 oz's in the nose.
