Originally Posted by
charlie1960
I had to take a round file to the holes and slightly slot them, worked out very well.
I also shimmed the back of the retracts with a popcicle stick to get the gear to lean just a touch forward.
Thanks Charlie
I might remove them and look at doing the same. Lot's of tension on those holes.
Did you just ream out the wood above the nuts to give a bit more wriggle room ?
