RCU Forums - View Single Post - Tamiya elevation unit quick fix
Old 06-17-2014 | 07:39 AM
ausf's Avatar
ausf
Originally Posted by bowlman
I had this happen several times on my Panther and Pershing this happens one you replace slipper clutch with solid gear then if you try to over elevate your Barrel or depress it more you end up stripping out the gear on the mech arm .
My fix was to mount a couple limiter switches in the turret so you could only go so high or low and it would stop barrel before stripping out gear .
Jimmy
That's great idea Jimmy. How would you wire it to the motor to stop it but still provide power to move in the opposite direction? I assume it's like the recoil unit.
