RE: Glow plug?
Thanks Darth, I'll try to lean up a little more. How hot does your vmax7 run? Does the heatsink boil spit? Mine will if the outside temperature is 90 degrees or so. Now that the air temperature is much cooler the engine produces little heat. Spit just sits there. Just trying to find the normal parameters.
Thanks, Mark
