the low end needle on the 115 effects only the idle. nothing else. if you get the engine a bit too rich on the high it will load up at mid and low throttle and the engine will dead stick. you have to set the needle just right. pretty much at peak maybe one click rich. no more or it will die in the middle. flown mine 100 times best engine ever.
