RCU Forums - View Single Post - CG check
Thread: CG check
Old 06-19-2014 | 01:20 AM
  #53
DagTheElder
Originally Posted by Malcolm H
Dag,
With respect this is the opposite of what I'm saying. Modern designs have plenty of potential pitch stability. The issue is with directional stability. Watch most of the current large fuselaged current designs going round an outside corner and you will see them slip off to one side. An increase in vertical area is what is required to deal with this.
Malcolm
Malcom,
If you move Your CG back for Your likings you must be prepared to ; a: Increase stab area. B: Fly With considerable negative trim.
This is "fisiks" to mantain balanse in Space (read air). The Pitch stability increases With larger stabs , thats correct!!!
Best Regards
