RCU Forums - View Single Post - Backdraft 3.5 tranny
Old 06-21-2014 | 08:04 AM
Shady9503
The gear that controls the shifting, the clutch, does infact have two screws on it, one holds it onto the transmission shaft, the other decides the shift point, it is only a grub screw and might have come out while driving, if it did the spring probably did too, but check your new clutch and loctite that little grubscrew or you WILL lose it, happened to me aswell
