Interesting finds there. The spider frame looks a lot like ours but no camera mount and looks like holes need to be drilled to mount the dome.
Not much difference in price either but free deliver for you guys might be the kicker
Upgraded the APM to 3.1.5 and I dont like it. Quad seems jittery and almost had a flyaway when I switched to loiter and it took off sideways.
Lucky I switched but to Stab in time and got it back. Also plenty of speed errors in the logs as well as an INS and I2C error from that flight.
The rest of the pack it worked ok but still flys funny.
Im sure they've crammed so much *hit into the board that it cant cope.
Going back to 3.1.4 which worked perfectly and see what happens.
A question for the guru. I want to use my 3s nanotech that dropped a cell from new in my Taranis.
If I cut the wire from the bad cell, then wire the others to a 2s connector, when I charge it will the other cell cause any problems. Dont want to start any fires
