Ok, started fitting the gear door panels. The first side I've fitted doesn't sit flush with the wheel bay. Protrudes by a few mm's. Might have to fiddle around to get it to lay flush.
One tip:
I quickly gave up on the manuals suggestion of tacking the gear door in place with CA and all those fiddly measurements, messy pencil marks etc.
I cut the pointy ends off two wooden meat sticks & sat them upright in each bolt hole on the gear door retainer. Lined the door up, pressed gently down & the result is two small pin holes, perfectly lined up & ready to drill the holes.
