RCU Forums - View Single Post - Leaking engine
Old 10-05-2003 | 10:04 PM
cheiro
Default RE: Leaking engine
Helis are meant to run rich...the muffer should be spitting out oil, small droplets... as for the crank case there should be a casket between the engine and the back cover make sure the bolts are tight. But for sure check the needle adjustments...
