From the published guidelines, it would appear as long as you are following the AMA guidelines, do not exceed 400', remain line of sight, fly in Type G airspace outside of an airport, they plan to leave us alone. Aircraft are limited to 55#, unless certified thru an agency (AMA is the only one I know of that currently has a program in the US). The next paragragraph after that basically creates whisteblower program that allows those who feel you are going outside those rules to notify the local FAA office for investigation. Sounds to me like they followed the AMA guidelines pretty closely, and are very adamant about recognizing commercial vs. non-commercial intentions. From my comprehension of this, there is more to come, and if you plan on doing anything for compensation you will require a license from some entity. It is not explained yet.
