This particular ARF was brought to market some time ago when higher capacity lipos were scarce or horribly expensive, hence the parallel connections to get more run time. A single pack will do the job nicely. Choose what ever capacity and rating that will fit without a great weight penalty. If you are planning 3D, lighter is better. If IMAC style aerobatics additional weight is preferred so the plane grooves and penetrates better.
