Originally Posted by
DocYates
SP don't confuse the issues. If you are classified as a "hobbyist" they will not prosecute. Take money or act otherwise and they will do so. It might be an extremely costly endeavor to pursue.
G
ENERAL.—Notwithstanding any other provision of law
relating to the incorporation of unmanned aircraft systems into
Federal Aviation Administration plans and policies, including this
subtitle, the Administrator of the Federal Aviation Administration
may not promulgate any rule or regulation regarding a model
aircraft, or an aircraft being developed as a model aircraft, if—
(1) the aircraft is flown strictly for hobby or recreational
use;
(2) the aircraft is operated in accordance with a communitybased
set of safety guidelines and within the programming
of a nationwide community-based organization;
(3) the aircraft is limited to not more than 55 pounds
unless otherwise certified through a design, construction,
inspection, flight test, and operational safety program administered
by a community-based organization;
(4) the aircraft is operated in a manner that does not
interfere with and gives way to any manned aircraft
If you fail to follow the CBO rules you may be in trouble. The FAA can and will prosecute if you create a hazard or cause damage or injury.
