Tim
Thanks, great info. I had thought to use the small tank as it would only be for the brakes, but now I will take your suggestion and use the large one. I think I got 3 or 4 of the large tanks as they came with the gear from Sierra. I, as well, wanted to do the run up and takeoff in a simulated scale length for the carrier, sounds like fun. As I understand it the controller leaks the air out in short bursts when you apply the brakes, is that correct?
