You mean this engine?
https://www.google.com/#q=anderson+s...+engine+images It should be easy.
You will need a thin aluminum washer to hold a tiny magnet & place it behind the prop. You will need to knurl it so the spacer washer and the prop will not slip. Get a cheap CD ignition and make a holder for the pick-up. Small battery to power the CD ignition.
Reason: add more data
