Originally Posted by
AirmanBob
I just got a Saito FA100 and put new bearings in it because the crankshaft was rusty. I polished the crank till it looked like chrome and oiled it all up real good. I wonder if its okay if I turn the carb 180 degrees so that the needle valve is pointing up when the engine is mounted sideways (with the exhaust pointing down)???? I did that with on OS91 and it worked great. Anyone?
Thanks, Airmanbob
Bob
That is how mine is setup, needle on the left, muffler on the right. I wonder why yours is on the right same side as the muffler, would be tricky to adjust and not get burned by the exhaust.
