Originally Posted by
Flynstuff
I honestly rotate at around 40 feet and climb out at a 45 deg angle.
I fly fly at about half throttle with main tank only. Land after 6 min with a little under half tank left
That's good info, I always build my stuff super light using the best weight saving techniques I can think of. I normally come up about 3 lbs less than stock weight, I try not to add all the bling just use my standard setup on every thing I build. Im looking forward to not having to worry about flight time with this jet. Thanks again
