I'm going to get the motor mounted before I glue the tail on. This way I can stand the fuse up on the end to line up the motor.
There was no thrust angle built into the firewall on this kit and the instructions make no mention of any thrust angles. I may mount the motor just slightly to the left so if I need to add some right thrust, the motor won't look crooked.
I just noticed that on my kit build Four Star 120, the engine is square on the end of the fuse and it flies perfect.
https://www.youtube.com/watch?v=dlX9DUxUJyY
