Originally Posted by
Rv7garage
That still seems like a LOT of weight- are you absolutely, 100% sure that you're balancing at the correct point??
I agree it is a lot and yes I am sure it is correct. Manual says 3.5" from LE which is where is set the balancer at. I even rechecked it and then took out a tape measure to make sure the numbers on the balancer were accurate.
