Originally Posted by
aymodeler
Is there any way you can put a spacer between the firewall and the engine mount to push the engine forward a bit? You could also try a heavy hub/spinner to put some extra weight as far forward as possible.
Your plane looks great, by the way. I just finished an SSE with as an electric conversion. With a 5S 4000 mah battery, up front, I am actually a touch nose heavy (about 1/8" - 3/16" ahead of the ideal CG).
Al
I concur, I quite like the black canopy too.
Your's is also fine looking AL, I imagine it will make a fun electric. Did you lighten it up, or build it stock?
