PS.....You don't normally use a check valve in the pressure line, do you..?
It WILL build excess pressure that is hard to control.
If you can get great runs without any gimmicks or gizmos, that's all that counts. You would need to be a swiss watch maker to build a backplate mounted pump for a .020..!
