I will add one thing sort of off topic.. Always keep in mind when you are bending not to put yourself in a position where you might drag your arm across the bending area of the wire IF IT SHOULD BREAK! once in awhile I have had the wire break when I was really pulling hard on some larger diameter stuff. It usually leaves a razor sharp tooth that you do not want to get caught on.. just a reminder.
