At the cable coupler. Turn fin should be close to CoG within 1/2" A mono hull is 1/3 of the total hull length.. measured from the transom. A hydroplane is just behind the back of the sponsons. CoG is measured with fuel on board. Do you mount the engine forward or back in the engine bay that's up to you.You'll get suggestions for both.
