throttle opening at idle?
Looking down the throat of the carb (.46 2-stroke), how much opening should there be at a decent idle? I assume full closed will kill the motor, unless there is enough air bleed through the low speed needle/air bleed adjustment on the throttle arm? Trying to set my throttle servo throws and get an engine broken in - I'm new to non-electric motors...
