RCU Forums - View Single Post - Flaperons, GP Dazzler
Old 10-06-2003 | 07:48 AM
bakes65's Avatar
bakes65
Default Flaperons, GP Dazzler
Hey Folks,
Got a GP Dazzler, maiden flight is fast approaching. I've connected my ailerons so I can use them as Flaps with my computer radio. My question is this: How much throw should I use for the flaps. (With the push of a switch, both alerons drop down creating extra lift for a little more gentle landing attitude.) I can adjust the throws on the radio so that won't be a problem. Instead of trial and error, which I'm NOT opposed to, I'd like some input as to a good recommended start point for the flap throws.
Also, while we're on the subject should I mix a little bit of down elevator to offset the nose up condition when using flaps? If so, what ratio?
Trial and error is fine, I'm just loking for a good starting point.
thanks in advance for the help!
