RCU Forums - View Single Post - Chipmunk Brotherhood.
Old 07-05-2014 | 08:55 AM
Zor
Banned
Default Some variations over the years
Originally Posted by TonyBuilder
The Chippie was a favorite of the RAF
It is said that the de Havilland DHC-1 Chipmunk looks the way an airplane should look. Designed as a military trainer, the "Chippie" has a tapered wing and a narrow, sleek fuselage that give it the appearance of a petite World War II fighter. It also has that distinctively shaped vertical fin, the signature of many de Havilland designs (including the D.H.98 Mosquito fighter/bomber).
As the propeller ticks to a stop, a new Chipmunk pilot usually just sits in the cockpit for a while wearing a smile that reveals his infatuation. The Chippie engenders that kind of affection from those lucky enough to fly one.
SPEC SHEET
De Havilland DHC-1 Chipmunk
Price as tested: $55,000
Specifications
Powerplant Rolls-Royce Gipsy Major 8 or 10-2, 4-cyl, inverted in-line, 145 hp @ 2,550 rpm
Recommended TBO 1,500 hr
Propeller Fairey Reed two-blade, fixed-pitch, 81-in dia
Length 25 ft 5 in
Height 7 ft
Wingspan 34 ft 4 in
Wing area 172.5 sq ft
Wing loading 12.8 lb/sq ft
Power loading 15.2 lb/hp
Seats 2
Empty weight (as tested) 1,517 lb
Max gross weight 2,200 lb
Max gross weight (aerobatics) 2,100 lb
Max useful load 683 lb
Payload w/full fuel 550 lb
Fuel capacity, std 22 gal
Oil capacity 8 qt
Baggage capacity 40 lb
Performance
Takeoff distance over 50-ft obstacle 1,350 ft
Max demonstrated crosswind component 10 kt
Rate of climb, sea level 800 fpm
Max level speed, sea level 120 KIAS
Cruise speed/range w/45-min rsv, std fuel (fuel consumption)
@ 75% power, 5,000 ft 95 kt/207 nm (7.5 gph)
Service ceiling 15,800 feet
Glide ratio 10.5:1
Landing distance over 50-ft obstacle 1,425 ft
Limiting and Recommended Airspeeds
Takeoff safety speed 56 KIAS
V X (best angle of climb) 56 KIAS
V Y (best rate of climb) 65 KIAS
V A (design maneuvering) 117 KIAS
V FE (max flap extended) 71 KIAS
V NO (max structural cruising) 155 KIAS
V NE (never exceed) 155 KIAS
Best-glide speed 60 KIAS
Final approach speed 60 KIAS
Max canopy-open speed 90 KIAS
V S1 (stall, clean) 47 KIAS
V S0 (stall, landing configuration) 43 KIAS
TB
Over the years and locations of fabrication some of the Chipmunk specifications have varied.
The gross weight has changed.
The recommended speed for various aerobatics have changed.
Some were not equipped with electric starters and some were.
The positive and negative G ratings have changed.
I think the above specs are typical of the most recent production.
Zor
