RCU Forums - View Single Post - Select Hobbies SkiniWag build thread
Thread
07-08-2014, 08:54 AM
16
hfenn
Prepare to assemble the front upper deck blocks. It is made from the 3/16" X 3/8" balsa stick and the laser cut center piece. Cut the laser cut piece so that you remove the area that is taken up by the center cabane. I glued the front piece to the side of one of the sticks and then glued on the other stick. You now have the center piece sandwiched in and it makes a guide for carving and sanding. After the assembly is glued in, then glue in the rear center piece. Carve, sand and blend according to the views on the plan.
Reply
Like
hfenn
View Public Profile
Send a private message to hfenn
Find More Posts by hfenn
View iTrader Profile
