Almost completely moved. Started to set-up my shop, will be remodeling this space after my Edge has been completed.
Tank has been plumbed, you can see how I ran the vent line if you look carefully in photo #3. I mounted the servos for the elevator halves and ran all the wires through the tube (rocket) that I had installed earlier in the build. It was a snap to just push the wires through and have them come out in the exact location that I wanted. I also installed one of four remote receivers in the tail and used the same chase to run the wire. The receiver that I am using is a 12 channel DSMX Power Safe Aircraft Receiver made by Spektrum.
