RCU Forums - View Single Post - DERIVATIVE, New 2X2
Old 07-09-2014 | 08:35 PM
  #232
drac1's Avatar
drac1
Matt, can you post a link to where you discussed taper sanding?
Do you bandsaw or hot wire the cores?
Do you make 2 cuts in the core to get the rib thickness or sand?
One more thing. Do you leave the foam block in while the ribs dry, and if so how do you stop the foam block from gluing to the skin and rib?
Might be a stupid question, but thanks anyway.
