RCU Forums - View Single Post - DERIVATIVE, New 2X2
Old 07-10-2014 | 06:23 AM
  #235
MTK
Originally Posted by serious power
' Hi Matt,
Would you consider .2oz carbon veil on the inside instead - is lighter than absorbed epoxy and adds more tensile strength across the grain. It would help with confidence re the sanding of the sheets .
Brian
Brian,
Stab panels are small (about 115 sq inches each) and don't see the load a wing does. Carbon veil inside will add a lot of course. The panel would not need spars. I chose to do it the way I show.
I am planning to use some veil inside the wing panels, to go along with the basswood spars. The whole sheet doesn't need veil in that configuration. With basswood spars it probably doesn't need any veil. I will do veil to about half span primarily to allow easier handling without concern about breaking through skins
