RCU Forums - View Single Post - How do you remove paint over spray from MonoKote ?
Old 07-13-2014 | 04:52 AM
TomCrump's Avatar
TomCrump
Originally Posted by Old Fart
This might sound weird but sometimes a bit of soft brown masking paper screwed up in a ball will remove it easily.
This may sound weird but a bit of masking would prevent the problem in the first place. Spraying without protecting the surrounding surfaces is not a good idea. The overspray has to go somewhere. It usually finds it's way to unprotected areas on our airframes.
Aerosol cans are much worse than spray equipment, too.
I recently painted three airframes within a month. Two were using HVLP spray equipment. One was an aerosol. The aerosol supplied 5 times the overspray, as the other two paint jobs, combined.
