You're begging for trouble by not using a BEC for the ignition if you truly feel you must run the whole plane on one battery. I think a better route is redundant receiver batteries that go to both the receiver and the BEC. That way you have redundancy to both systems with no weight penalty compared to the separate battery setup.
So what battery and servos are you running? Have you checked your amp draw?
