Hi SpaceCase,
You should never see any type of glitching due to programming on your transmitter.
If you are referring to odd or unexpected servo movements, it may be that you have another Pmix active that is causing your problems. If in doubt, it would be suggested to go into a completely blank model on your transmitter and set your mix up there. If there is no unusual behavior seen then your transmitter is fine, and again what you are noting may be due to another active Pmix.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (
www.futaba-rc.com)
