RCU Forums - View Single Post - 3pk question
Thread: 3pk question
Old 10-06-2003 | 02:44 PM
Zman-RCU
Default RE: 3pk question
Thanks Krysta,
I tried that, here is what is happening. I went to adjuster menu, selected throttle and the neutral menu came up. I then moved trigger back so the neutral was where I wanted and pressed the + and - keys. Nothing happened. The only key I can press and make something happen is the "sel" key. Once I do that the brake and forward menu comes up after I go through these, it said system failed, did not adjust.
What am I doing wrong?
Mike
