Fair enough. I am using the same process I used to bind it to my DX8 which works fine with it. The TM1000 and the RX are within 4" of each other and I a have the DX9 within 2' or less of them both. The RX is a 6210 which has the data port and worked with the DX8 and the TM1000. I can rebind to the DX8 just to double check it.
I also updated the firmware on the DX9 and tried again but still no joy. Will try again in a bit.
