RCU Forums - View Single Post - Align t-rex 600n project
Old 07-16-2014 | 09:53 PM
flyingjmerritt
well made little progress got the gas tank in that was in a parts lot i bought on ebay along with some misc hardware. picked out what i needed and going to sell the rest.
skipped ahead working on the tail boom mount. put 2 new bearings in the umbrella gear case. now all i need is the top and bottom small bearings,front drive gear,front umbrella gear. also took out the plastic mounting bolts because i did not like the plastic mounting bolts(breaks to easy and strips out easy) and replaced them with aluminum mounting bolts(much stronger and don't strip out as bad).
now all i need is the other parts and this part will be ready for assembly later on. now all i need to work on is getting a new os engine,upgraded aluminum cooling fan(aluminum cooling fan cools better than factory plastic fans) and get landing gear parts. then i can move onto the next step and page.
ID:	2014863   Click image for larger version
ID:	2014864   Click image for larger version
