It shouldn't have the slightest effect on your "starting drill", however that drastic a weather change could have a dramatic change in the compression and needle valve settings required to get the engine to start.
Just richen it up, knock the compression setting right back, and re-establish a set of settings where it will run again.
Just check that the contra piston actually does move when you back off the comp.
