I hope this is the correct group for this question.
I'm trying to find some information about an odd Fox C/L engine I have. It has a fairly large, square intake and the front housing and rear cover are held on by four bolts, each. The rear cover has a pressure tap.
Unlike my other Fox engine (a .35), there is no number visible in the small raised circle beneath the word FOX on the case.
What's confusing me is that the exhaust port is on the left side, like my Torpedo C/L engines. I'm not sure if a previous owner swapped the front and rear or if it came that way from Fox. A search of the internet did not provide an answer. I do know that the engine just screamed when I tested it. It's definitely working well.
Thank you,
Richard
