Ray.. if you are still following this thread and want a trick to try on your soldering fitting while they are on the plane..Tear off a couple sheets of aluminum foil and lay it over the solder section, then plug in your piano wires to the locations..clean, wrap with wire, flux... now if you are careful you can use a torch without immediately destroying the balsa.
