RCU Forums - View Single Post - Allure by Bryan Hebert
Old 07-19-2014 | 02:08 PM
  #76
OhD
Originally Posted by jim woodward
Great reading all the inputs. Bryan - big congratulations on bringing the Allure to market! Looks great! I'd like to add one thing regarding all this trim talk - the pilot needs to detect immediately if/when the plane does something that was uncommanded... Every flight or sequence is a trim flight in my book.
Jim
edit- if you are like me and end up settling with some pitch mix, Futaba has a brilliant "Expo" mix!!! I have often found that I may end up with 2-4% needed! but with + 60% expo. This makes the mix happen closer to neutral on the rudder stick, where as a pure linear mix would need a huge number to have any action around neutral.
Jim, I'm using a Jeti DS-16 now but as I remember Futaba also allows you to mix with a multi point "line" curve. I think you will find it more brilliant as you can adjust the points for amplitude and stick position. And you can reverse the slopes if you need to, that is, less mix at large inputs. Let me know what you think.
Jim O
