Originally Posted by
fredo
Hi guys, I have finally started my build after a long delay. Ok, just a basic question. That loose air hose (on the pic), I believe is for the air tank..right? There's also another one on top of the tray ..I think for pressurising. In the old days I used to use bicycle valve but it's been a long time since I dealt with retracts.. so what pressure valves are you guys using nowadays? Oh, I forgot to mention I have a pro-wired version with all cables, hoses and pneumatics installed.
Here is what I use for my air system. The check valve holds the air in the jet.
http://www.dreamworksrc.com/catalog/...ith-Checkvalve
These are helpful too. You will only need one.
http://www.dreamworksrc.com/catalog/Air-Gauge-Single
This is the best inflator I've ever used. Has a digital readout on the handle too. You will have to buy the 19volt battery separate, but if you get this, get a leaf blower too since the batteries are interchangeable. The leaf blower cuts down on how much your ECU battery is used cooling the turbine after shut down. I just stick the blower nozzle in the intake and let it blow cool air until the turbine completes the cooling cycle.
http://www.sears.com/craftsman-c3-19...1&blockType=G1
Best of luck!
Paul
