What you are see ones the vent working once you pull the overflow tank line off. The fuel line is full of fuel and working as a syphon until the fuel level goes below the inlet level of your vent line. No way to stop that from happening that I know of if you engine is not running per than having the outlet line exit higher than your tank.
