Hi guys,
Thanks for your replies.
I'll definitely PM Alan for those cables.
Like said, I do like the rest of the Weatronic gear, e.g. the LinkVario Duo with TEK and the multiple setup options of GC, but the cable issue in combination with that other problem really aggravated me past the boiling point sometimes.
I'll run some tests with both FX30's besides each other to draw a conclusion and let you know.
Originally Posted by
Edgar Perez
I hope they hurry up with the Bat 60. This weekend I was getting movement in the rudder when moving the elevator stick, similar to a programmable mix. There was no mix, just some kind on interference within my Futaba 12FG.
Had that once too. When I moved the elevator my rudder moved with it.
Looked like somesort of mix too but it was an easier fix. (Well fix, it showed where I F-ed up lol
I had the elevator control rod running alongside the receiver.
It was a Micro10 with Gyro and at big throws the elevator pushrod pushed the receiver over a lil bit activating the gyro on the rudder.
Probably has nothing to do with your problem but was a nice story to tell.
I assume you fly mode 1 but if you hook your set up to GC it will most likely show the rudder throws making it easier to see what is actually happening.
