Matt,
I'll be using the "T" fittings and push in fittings. both on air and fuel. normally I wont use any tygon in the whole fuel system.
fittings on the pistons are standard indeed.... with the 3mm festo tube, they do need securing. on the valves I'll replace the standard nipples with Festo Push in as well (3mm to M3)
Wim
